Kazes☻2008-01-19 13:16:19 // 1275
Egész jó pofa, ez lehet a 480ES turbó ihletője, de erre van az "offos verdák" topic. Bocsesz. :-)
martin-i2008-01-19 13:10:34 // 1274
Bocsánat, van neki neve is:
Volvo P1800 ES (a "sima P1800-t ismertem ezt a verzót még nem láttam)
"In the autumn of 1971, a new version of Volvo's famous 1800 model was presented. The new version was called the 1800ES.
The 1800ES had a newly-designed rear end compared with the previous version of the 1800. The roof lines had been extended and the car had a profile that was more reminiscent of an estate. Completely in line with Volvo's tradition of building estates to match the development of customer lifestyles and the increase in the size of luggage compartments to provide the extra space required for golfing equipment, for example.
Under the surface, the technology in the 1800ES was the same as that in the other 1800 models.
The new version was produced for two model years, 1972 and 1973. In 1972, both versions were produced in simultaneously, but only the 1800ES was produced in 1973.
When the last cars were built in 1973 and production was wound up, this was due to the increasingly rigorous safety requirements in the USA, in particular, which would quite simply have been too expensive to comply with.
Technical facts:
Prod. years: 1971-1973
Prod. volume: 8,078
Body style: 2+2-seater coupé
Engine: 4-cylinder, in-line, overhead valves, 1,986 cc (121 cu.in.), 88.9 x 80 mm, 124 bhp.
Transmission: Electrical overdrive, 4-speed manual with floor-mounted gear lever. 3-speed automatic with gear lever on steering column.
Brakes: Hydraulic, disc brakes on all four wheels.
Dimensions: Overall length 438 cm/172.5", wheelbase 245 cm/96.5".
Technical facts:
Prod. volume: 8,078
martin-i2008-01-19 13:08:34 // 1273
Scott2008-01-13 20:39:50 // 1272
GT Ɨ|ѯ2008-01-13 19:49:21 // 1271
Szépek:-)
gyerekkori matchboxaim jutnak eszembe:-))
veteranviking2008-01-13 14:53:52 // 1270
veteranviking2008-01-13 14:46:06 // 1269
Hi!
Az első képen látható Varga Józsié, még tavaly felkért minket, hogy a 2008-as szezonban mi szervizeljük a versagépét.
Még tárgyalunk az anyagiakról, remélem meg tudunk egyezni!
Mégse mondhatom neki, h ingyé is vállalnám:-))))))
ystuc2008-01-13 09:45:58 // 1268
Te is felújításra szorulsz? :-))
Vader (a Gróf)2008-01-13 08:48:20 // 1267
Gyönyörű és ritka!
Fel lehet ezeket még támasztani?Főleg a Volumex-et...
Marklar1552008-01-13 02:03:13 // 1266
Áki2008-01-12 23:20:53 // 1265
Én már régóta szeretem ezt a tipust,a Különben Dühbe jövünk c. Bud Spencer film óta!:-)
Sok sikert hozzá,majd tájékoztass minket,hogy hogy áll a restauráció!;-)
Ali762008-01-12 23:15:43 // 1264
veteranviking2008-01-12 22:49:06 // 1263
Szóval, Egerben leltem.
Tavaly tetszett meg ez a típus.
A magyar rally bajnokságban is megy, idén talán már 3 db. is Hystoric kategóriában.
Áki2008-01-12 18:54:01 // 1262
Megfog!Majd én megszólítalak!:-)))
ystuc2008-01-12 18:51:47 // 1261
Hol lehet fellelni ilyen autókat? Engem is megszólíthatna már valami... :-)
Whiteskull2008-01-12 15:40:29 // 1260
Gratulálok! :))))
Elhiszem, hogy nem tudtál elmenni mellette. :)))
Áki2008-01-12 15:37:26 // 1259
Wow,ezt hol találtad??Nagy kedvencem ez az Escort,sok sikert hozzá!:-)
veteranviking2008-01-12 12:36:56 // 1258
GT Ɨ|ѯ2008-01-09 08:49:02 // 1257
Meg a Csajka ( is ) :-))
tt (tt Alfa team)2008-01-08 20:41:25 // 1256
Nem vészes, szinte szép!
Ferke2008-01-07 15:12:54 // 1255
gondolom azért az is eléggé felújítandó volt?!:))
Ferke2008-01-07 15:11:24 // 1254
Hú de durvaaa!:)))
GT Ɨ|ѯ2008-01-01 20:12:40 // 1253
Kár a bordóbőr tetőért:-(
tt (tt Alfa team)2007-12-31 18:17:34 // 1252
Igen, ezt én is néztem. Még az ára is jó! (lenne) :))
tt (tt Alfa team)2007-12-31 17:47:57 // 1250
Debrecenben egy keresedésben láttam egy egész szépet belőle, fehér színben. Nemrég hozták Ukrajnából! (800k)
Liquid2007-12-31 17:17:47 // 1249
ez nagyon szép, kellett vele dolgozni rendesen, hogy ilyen legyen
tt (tt Alfa team)2007-12-31 16:20:35 // 1248
GT Ɨ|ѯ2007-12-31 15:52:06 // 1247
Marklar1552007-12-26 21:43:27 // 1244
Amúgy ez már régen volt. Viszonylag sokáig nem vette észre, hogy eltőrtem a kerekeit:)))
Scott2007-12-26 21:29:33 // 1243
Na de nem mindegy milyen Alfa.. :)
Áki2007-12-26 21:09:09 // 1242
Retro Tuning!:-)) Szegény féltve örzött emlék...az eredeti állapota is már csak emlék!:-)
Marklar1552007-12-26 21:03:25 // 1241
Áki2007-12-26 20:49:53 // 1240
Tologattam a parkettán és valsz brümmögtem hozzá!:D
Marklar1552007-12-26 20:23:29 // 1239
Amúgy anno nekem is nagyon bejött a 127-es. Az első szériás is, de inkább a 2.
Lehet, hogy ezért is vettem 127-es FIAT motoros trabit anno? :)
Legalább a szíve...
Legalább a szíve...
Marklar1552007-12-26 20:21:42 // 1238
S mit csináltál a kék strandkorláttal???
:-PPP
:-PPP
Áki2007-12-26 18:37:14 // 1237
Az lehet,hogy nem gyártották de még futottak..sőt volt műanyag autóban is ilyenem..gyönyörű strand korlát kékben!:-)))
Marklar1552007-12-26 18:16:11 // 1236
Hmm.
Az original 127est már nem is gyártották mikor Te születtél! :)))
(kivéve a kombit, mert a haveromnak van egy 86-os 1,3D-je, de az meg brazíl, vagy mi)
Áki2007-12-25 14:02:35 // 1235
Az R4-es nagy kedvencem...a 127es Fiat meg már gyerekkori emlék..a nosztaliga kedvenc!:D
Marklar1552007-12-25 13:08:15 // 1234
Mit érne Neked egy ilyen 127esre egy Vadi új díszrács? :)
Marklar1552007-12-25 13:06:48 // 1233
Akkor már értem:)
Amúgy a nyáron Szerbiában rengeteg R4 est láttam. Kimondottan feltűnt, hogy milyen sok van még ott.
Ali762007-12-25 11:35:06 // 1231
martin-i2007-12-25 10:53:12 // 1230
no persze, az a legelső! :-)
ystuc2007-12-25 10:43:03 // 1229
Én ezt az utolsó mondatot inkább úgy mondanám, hogy "Alfa nélkül lehet élni, de minek?" :-)
martin-i2007-12-25 10:38:56 // 1228
GT Ɨ|ѯ2007-12-25 10:28:22 // 1227
Szerintem 100 is sok ezért..:-(
ystuc2007-12-25 10:16:28 // 1226
Ismerősöm vett ilyen R4-et pár hónapja. Azaz nem ilyet, hanem a dobozos változatát. És ő alapította meg a magyarországi R4 klubot. Voltam is az első találkozójukon, igaz, nem voltak sokan, de érdekes volt annyi R4-est (köztük egész különlegeseket is) egy helyen látni. :-)
