Fórum >> Típusok >> 159
RomeoOne2016-08-26 22:17:17 // 85184
Megcsináltattam végre a kipufogót is, nagyon elégedett vagyok vele :)
Blogomban a részletek.
Gyapi Ɨ|ѯ2016-08-26 22:11:42 // 85183
itt is találhatsz hozzá dolgokat http://www.blueandme.net
Deo2016-08-26 11:27:25 // 85182
ez igaz lehet? (térkép)
http://www.ebay.it/itm/Mappa-Europa-NW-2016-aggiornamento-com-alfa-159-brera-spider-/222229635916?hash=item33bdeb234c:g:vusAAOSwB9xXOw5Z
Deo2016-08-26 11:08:55 // 85181
kezdek megvilágosodni.... kéne valami setup cd - nyelvekkel :
"For setting voice recognition language, the
user will be requested to insert the Setup CD.
WARNINGBefore starting the language
change procedure, check whether the setup
CD (provided with the car) is present and
ready for use. The ignition key shall be at
MAR.
WARNINGIf the Setup CD is not inserted, the new set language will be operative
for written text only. Voice recognition (and
instruction coming from the system) language
will be the default or the preset one."
forrás :
https://www.fiat-lancia.org.rs/Manuals/AlfaRomeo/GT/ConnectNav&Nav+.pdf
lehet megoldás is lesz? :
it's as simple as this:
When I first bought the alfa, I messed with te sat nav settings and couldn't find anything to do with language. I then contacted a very helpful guy at the Alfa Dealership in Lincoln Called Lee, who told me that all you need to do is to change the language using the trip computer controls on the dash next to the odometer reset buttons. Switch the ignition on then use the following method:
Change display language to Italian (make notes of every step to save confusion in next stage)
Turn ignition off and remove key for 90 secs
Insert Key and switch ignition back on
Using notes made in step 1, change language back to English
Switch Ignition off and remove key for 90 secs
Swich back on and play with connect nav
Hey Presto! back in English!
forrás :
http://www.alfaowner.com/Forum/ice-andamp-blueandamp-me/250622-setup-disk-for-changing-language.html
Erhard 242 (Pure Energy)2016-08-26 10:37:54 // 85180
nem tudom de adok hozzá egyet ha ezen múlik :)
AdiArsenal2016-08-26 10:33:44 // 85179
Egr ház fedele lett cserélve azt tudni?
Deo2016-08-26 10:03:42 // 85178
Valaki aki a navis rádión szoftvert frissitett - be tudja állítani hogy a hang is angol nyelvű legyen - ne csak a felirat? tegnap a frissités rendben lement - de olasz felirat/olasz beszéd -re állt aztán ki be kapcs után hajlandó volt angol/ olaszra - (pillanatnyilag olaszul beszél - nem annyira vágom a nyelvet...) de ha már magyar nincs akkor legalább angol / angol - lenne a szimpatikus :)
tippek-trükkök?
illetve van valakinek valmi frissnek mondható térképe - főkép Magyarország tekintetében ?
Erhard 242 (Pure Energy)2016-08-26 09:32:17 // 85177
állapotba nem igazán lehet belekötni , pár kavicsfelverődés a motorháztetőn, sérülés és törés, húzás mentes, km valós, végig vezetett szervizkönyv én mentem vele, hibátlan ...
AdiArsenal2016-08-26 09:24:48 // 85176
Állapot, km valós-e, szervizek?
Liquid2016-08-26 09:01:31 // 85174
ezzel kezdtem a napot én is :)
yani🍀2016-08-26 08:51:26 // 85173
Tudom, hogy van 156-os topic is, de jó volt elolvasni
Erhard 242 (Pure Energy)2016-08-26 08:11:13 // 85172
mit szeretnél róla tudni?
emGéza2016-08-26 07:17:40 // 85171
És tegnap megejtettük a futómű állapot felmérést !
Eredmény , a "nagypajszer" segítségével , kezdődő alsó lengőkargömbfej lógás .
Néztem az árakat 40/db-tól . Mivel nem hallani a kopogását , annyira most nem
kapkodok vele .Azért lehet , hogy kiütöm a helyéről a gombfejet szemrevételezni !
Két hete a 47-be cseréltem , na , az kopogott is rendesen . Kiszedve egy kisebb
harangjáték előadást is láthattunk . De szép volt ! :-D A szegedi se rossz ;-)
Akkor tanácsként kaptam , hogy újítsam fel ...
A 159 alsó lengőkarát , érdemes/lehet/ár és értékarányba , ha lehet , felújítani ?
AdiArsenal2016-08-26 07:08:02 // 85170
emGéza2016-08-25 21:08:41 // 85169
Hoppácska ! ;-)
Végre lecseréltem a 225/45-t , 235/50-re . Persze a 17" az maradt .
És a gyári leszen a téli , ha el nem cserélem ...
Tudom-tudom , 18"-tól kezdődik a méret .
Haddel2016-08-25 19:19:37 // 85168
Én is! Áldassék a neve!😃
Marcox2016-08-25 13:45:00 // 85167
Ezt az alkatrészt cserélte már valaki? Valami kuplung rugóvezető vagy mi a bánat a neve...
71740402
Gyapi Ɨ|ѯ2016-08-25 13:24:12 // 85166
ilyen lett a bőrök rendbehozatala után....
blog
Deo2016-08-25 10:40:44 // 85165
Köszönöm szépen :)
atika2016-08-25 10:06:55 // 85164
Lökhárító le-fel szerelését köszönjük droberto-nak. Én is ennek a segítségével hajtottam végre a műveletet.
http://alfaamore.hu/tagok/droberto/autok/8468/blog/16936
Gyapi Ɨ|ѯ2016-08-25 09:46:33 // 85163
akkor nem szedem ki, inkább bedobok még 4-5 pókot, feltuningolom a vasat 50 szeműre :D
Kolci2016-08-25 08:24:44 // 85162
Eddig 8 szemű volt most meg 16 :)
Deo2016-08-25 08:04:34 // 85161
Lökös leszedéshez valami instrukció mikre figyeljek?
Lexlutor2016-08-24 20:02:05 // 85160
Lökháritót le kell szedni és három csavar fogja ahogy írtad. Foncsor rész müanyag. Lencsét ki tudod törölni szétszedés nélkül. Vékony müanyag rugalmas pálca (2-3 mm) végére pici rony rögzítve. Felülröl lencse felöl benyúlva. Nem egyszerű , de nem is vészes. Maga a búra sokat levesz a fényből kis matsággal is (tapasztalat).
Deo2016-08-24 15:10:59 // 85159
Gyapi Ɨ|ѯ
Legalább az ő szemei is segítenek a látásban :)
Gyapi Ɨ|ѯ2016-08-24 14:59:51 // 85158
az enyém nem poros, hanem pókos
nem tudom hogy mászott bele, de emiatt nem fogom szétszedni a lámpát
Deo2016-08-24 13:41:15 // 85157
ProCarlos !
Sőt Lexlutor képei közt is találtam :
http://www.alfaamore.hu/kepnezo/blog/29343?num=3
ez alapján ennek is viztiszta lencsének kellene lenni
Deo2016-08-24 13:14:32 // 85156
proCarlos !
itt a 164-166 forumon láttam egy képet a lencséről :
http://alfaamore.hu/forum/alfa_romeo_164_166?m=16370687
poros nem poros verzioban
meg lejjebb a tükörről mármint a foncsor rossz és jó verzióban - ha a lámpa nem is biztos hogy ugyanaz - attól még lehet ugyanez lehet a helyzet nálam...
kérdés egy maradt - le kell szedni a lököst mindenkép?
proCarlos2016-08-24 12:57:21 // 85155
Deo!
Nekem gyári bixenon projektor, és én is küzdök, vagyis küzdöttem vele. Xenon ízzók régiék el voltak színeződve teljesen. Most már ég és föld, de még tartós éjszakai teszt hátravan.
Viszont, amire tudok válaszolni, pont nekem is ez tűnt fel, (azóta minden off-os projektoros autóra rápillantok), hogy az enyém ugyanilyen, mint a tied. Azaz nem vízüveg átlátszó, mint minden rendes projektor, hanem ez a barázdás felület, amit írtál, meg mintha picit selyempapír lenne benne.. :)
Nem tudom, hogy ennek ilyennek kéne lennie, de az biztos, a víztiszta átlátszó nagyítós bármilyen projektor jobb kell, hogy legyen..
Deo2016-08-24 11:21:55 // 85154
Lexlutor!
a lámpa kiszerelése hogy történik ? lökhárítót le kell venni gondolom és 3 csavar fogja 2 fenn egy lent?
bele világitottam a lámpa szemébe - nekem ugy tünik hogy nem átlátszó - jó persze nincs össze hasonlítási alapom hog ykellene kinézni egy ilyen projektornak - de mivel házimozihoz való projektorom van - és ott átlátszó :) meg az előző kocsimon is átlátszó volt - okkal feltételezem hogy átlátszónak - üveg szerűnek kéne lenni- ez meg belenézek és egyenletesen nem átlátszó - kb olyan mint az irás vetítő nagy prizma felülete - mármint amire rá tesszük a papirt - ilyen egyenletes mikrobarázdáltnak tűnik a felület rávilágitva - de maga az üveg rész nem áttetsző- nincs egy oylan kép ahol azt jól lehet látni hogy kellene kinéznie?
a másik amit látok szétszedés nélkül hogy a lámpa foncsorja felül levő felületen máladozik kb kisujj körömnyi területen ... - kérdésem az hogy ez a reflektor rész ez miből van - müanyag vagy fém? illetve a foncsor réteg az a homoru oldalán van - vagy kivülről és tátetsző müanyag a reflektor anyaga?
mondjuk ha ki tudom szedni a lámpát - megnézem :)
azt feltételezem hogy lámpa test kiszedése nélkül nem tudom se a reflektrot - se a projektor lencsét kiszedni hátulról- beszerelt állapotban...
BigBratyó2016-08-24 07:56:02 // 85153
Szia. D.Z. Tuninghoz vittem trélerrel az autót, mint kiderült a kábelkötegben volt szakadás. Így még nyertem egy-két hónapot a váltó szerelésig. Még mindig keresek jó automata váltóst. Mondjuk a DZ Tuning is meg tudja csinálni.
Piritu - 1.000.0002016-08-24 06:58:18 // 85152
Van jobb is. A tankolások közti átlagsebesség és a fogyasztás összefüggése trendvonallal:
Piritu - 1.000.0002016-08-24 06:53:17 // 85151
A kivágáskor lemarat :-(
Szóval a mért és a mutatott fogyasztás különbsége van a képen. Általában többet mutatott a valósnál.
RomeoOne2016-08-23 23:09:15 // 85150
Mondjuk így, hogy nincs feltüntetve, hogy mi van a függőleges tengelyen, nem egyértelmű, hogy ez most jó vagy rossz.
Gyapi Ɨ|ѯ2016-08-23 22:55:33 // 85149
aztamindenit.... utoljára a Star Trekben láttam ilyen grafikont, mikor a plazma hajtómű túlterhelés tesztjét végezték :D
Piritu - 1.000.0002016-08-23 22:23:21 // 85148
Kérdés, hogy mikor nulláztad az "A" számlálót. A mutatott fogyasztáshoz ez a távolság tartozik.
Greentimus2016-08-23 21:46:45 // 85147
Travel distance: 1013 km
Vagy ez lenne a valós km?
Erhard 242 (Pure Energy)2016-08-23 21:25:15 // 85146
nekem elég pontosan mér, komp alapján 9,7 volt a valóságban 9,67...
Piritu - 1.000.0002016-08-23 21:25:00 // 85145
Nekem ennyit csalt tankolásonként:
b00772016-08-23 21:21:19 // 85144
Szia,
Nekem sem valami pontos, computer alapján legutóbb is 6,3l - 6,5l körül volt, ha jól emlékszem. Teletankolásos méréssel pedig pontosan 7,3l-re jött ki. Legközelebb már feljegyzem a computer által mértet is pontosan. De a lényeg a lényeg, hogy közel 1l-el eltér...
Piritu - 1.000.0002016-08-23 21:17:39 // 85143
Tankold tele és akkor kiderül. Nekem az alsó vonalnál általában 55 liter ment bele, a tiedben most több van.
Ennyit nem csalhat a comp.
Haddel2016-08-23 21:15:15 // 85142
Felbertauern strasse. Útban Hintersee-hez😃 Ausztria.
Liquid2016-08-23 21:02:21 // 85141
Így nem nagyon lehet számolni, túl sok. a változó.
Greentimus2016-08-23 20:33:39 // 85140
A fogyasztásommal valami nem kerek.
Fullra tankoltam az autót, mentem vele 120 km-t, majd lenulláztam a számlálót. Azóta pedig beleraktam 645 kmt, tehát a tele tankolás óta 765 km-t autóztam. Reggel kivillant a sárga tankjel, tehát kb 12 L gázolaj lehet még a kocsiban.
Ez alapján a fogyasztásom: 7.5 L/100
A computer szerint pedig: 5.4 L/100
Hol a bibi?
RomeoOne2016-08-23 20:33:26 // 85139
Múlt hétvégén volt itt a II. fadd-dombori street car találkozó. Volt pár Alfás, de azért túl sokan nem képviseltettük magunkat. Majd legközelebb előre szervezünk :)
Belekerültem a promó videóba is, 12 mp-nél :D
Ezt a 159-est meg akartam keresni amore-n rendszám alapján. Az elejét ütöttem be, és Shadin-t dobta ki, kicsit meglepődtem :D
Az enyémnek csak a fara került rá egy képre :D
Piritu - 1.000.0002016-08-23 20:33:07 // 85138
Hol készült a kép?
Gondolom egy csinos szerpentinen mentél éppen felfelé :-)
Haddel2016-08-23 19:57:24 // 85137
Köszi😃 igen ,jó ez a vetitett háttér😃
fazek2016-08-23 19:53:26 // 85136
Gyönyörű!!! ( A táj is!)
Haddel2016-08-23 19:02:15 // 85135
